I have the money to lend you Simon but they are frozen assets that you and only you can access and I would need your assistance in transferring them via the Solomon Islands
Just putting it out there, Faythe is probably the worst name in the world that you could give someone.
Not only is it unoriginally hipster that you want to swap the i for a y, but you add an unnecessary and pretentious e on the end, then just the whole concept of naming your child after a belief system in the first place. It's like a multi-level troll and I hate it.
hipster?
more like straight bogan
Every paddock from chirnside park to eildon covered in frost. Bit nippy.
Apparently they closed down mt donna buang over the weekend cause so many people rocked up. 2hr queue up the mountain. Warburton was a carpark.
Yup, they sure did!
Also closed road up to Mt Macedon for about 48 hours as too many were going up & was getting dangerous
i know of one tuner whos notorious for bad cold starts on eth.....
so might not be plugs dude.....
There is no such thing as a perfect start on a cold melbourne day on e85.
really its
1) Does the car ACTUALLY start in under 30 seconds (maybe multiple tries, couple stalls, etc)
if yes: Your car is fine, get over it
if no: Something is probably up
I reckon people saying "lolz cold start on e85 is bad" is because they have an aneurysm if the car cranks more than once.
Source - f**ked with cold starts on e85 for literally multiple hours a day over two weeks, ended up raging at fuel pump.
anymore jerbs you can hook me up with?
my stuff wont be repo-ed but would be nice to be full time.
send me resume.
only draw back in only area that might be hiring ATM, is full of Asian females..so you might have to get daddy to buy you a brand name bag to fit it.
send me resume.
I have a Bally and also a prada, which is more suitable?
and you has pm. if resume sucks, tell me too.
Guest
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
