send me resume.
only draw back in only area that might be hiring ATM, is full of Asian females..so you might have to get daddy to buy you a brand name bag to fit it.
Sounds attractive to me, might need to send you a PM too so then Alvin and I can go man bag shopping.
i know of one tuner whos notorious for bad cold starts on eth.....
so might not be plugs dude.....
My car was tuned on a 30 degree day so I doubt the cold start is any good. Plus the copper plugs have been in there for 3 years now so I might swap them out and see how I go.
15 goes at starting is the worst it has ever been. Usually starts after 2 or 3.
  • Like 1
I've got about 6 wooden pallets sitting here in Cheltenham that are about to go to the tip, and 6 black plastic but they won't be much use...
If you want to travel, come take them ;)
Is Artz new jerb near you? He has a ute... :P
Otherwise, I can't fit too many pallets in the stagea, and not even a chair in the back of the evo. lol.
Anyone selling 4-stud of PCD 4x100 wheels? The missus's Civic could do with some new shoes.
just sold my spare, spare set.
be prep'd for a shock. you can get decent 17's with good tyres in any other sp, for less than 14's in 4x100,
f**king honda fags have killed it.
i got some bmw bottle caps in the garage with bf goodrich semi slicks, brand new too lol.
Shiiiiiiiiiiit. Not chasing anything special, just something better than the factory 14" steel wheels :(
Anyone?
14 inch tyres are a nightmare to find anything decent in, so maybe look for 15s? have a look on gummers?!?
Nah, not looking for any size in particular. She's keen on any wheels that are bigger than the stock 14", so open to 15s, 16s and 17s.
Had a look on gumtree and full of friggin' dreamers who think their Bob Jane specials are worth as much as genuine forged japper rims. Cocks.
told ya. 4x100 is a kent........ and most are ugly as f**k too. i stuck with bigger oem wheels, maybe look at the bigger hondas, see if there is anything cheap?!
Yeah I know. Worst aprt is, the missus brought a set of matte black 4x100 rims in a tough offset and look mint (look almost like TE37s) but the offset was too aggressive for her as she didn't want camber of anything like that, so looking to sell them or trade them :(
Guest
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
