Instead, I'll leave you with this:
Wouldn't have mind doing that except I was far from all by myself.
hope the interview and assessment centre went well bro! good luck with the results.
thanks hipsterman!
Really hope I get to the next round, will have to shout wasteland some springsrolls if i get the job lol
um go to the lounge and relax with free food/drink?
ummm..... I don't even get free wifi let along food/drink :closedeyes:
thanks hipsterman!
in for springrolls meet! or pho if it's still cold :P
Tiger airways, cheap and nasty for us fellow unemployed eng graduates :thumbsup:
haha for domestic could probably get jetstar to price beat :P
ok travel rant for the day.
looking at a hotel in Fiji for a short break.
4 nights for 2 people.
they have 2 packages.
both same room
1 is room only
1 is room plus breakfast.
$620AU difference.
how the hell can breakfast be $75 per person per day!
How are ya'll getting 27gb/month?
I'm on 1GB/month and average about 1.5GB/month... there's a bug in my plan where excess usage gets absorbed into my cap... so I need to his 3+GB before I actually start getting charged
Every time they call me, they're unable to offer me more than 1gb of data without increasing my monthly spend of $49 to something stupid like $60+, even with offers to recontract for 24 months if I had more data applied.
Want to stay with Telstra as well...
'Unlimited' telstra 4g here hehe!
Well we have ~350 work iphones with 5GB pooled data we never get close to that so yeah.
Think the most I've got it to was like 60GB lol boss is like wtf
Edited by UNR33L
Unles its a buffet and yourself and your travel partner eat like buffalo I'm going with rip off.
When I was in fiji we got our meals included at our resort, if we didn't it was something stupid like 20 for breakfast, 20 for lunch and 30 for dinner... plus drinks obviously. was too far from anywhere else, and the food quality was good, so was happy to pay for the meal package with the room.
No buffalo eating required, the 3-4 courses per meal were more than enough :P
Guest
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
