I had rare once, was really tasty but stomach felt funny afterwards.
bad but expected news for the pulsar: engine out, probably did bottom end bearing(s). the cause: most probably oil issues, like the whole oil cooler system wasn't functioning.
what's even worse is that now I'll pour more money into it... so many plans already. never ending
Wait, is this a new development or finally pulling down after a few months back? Sounds like you need to buy something more reliable and less prone to oiling issues... like an RB26 :P
this is from May. sounded like a bearing to me, and oil pressure had been very funny that day and seems like the two went hand in hand.
want to get heaps done while its down-time, but dont want to replace everything... is it really worth getting new a gasket kit for a 2500km old engine? head and exahust are metal multi-layer gaskets so you could easily re-use them, non?
what about rear main seal etc?
i know you dont want any of them to leak... but we're talking a few hundred bucks in good quality brand new parts here...
oh and the car killed my odyssey battery too :rolleyes: so need car electrical sussed out like 2 years ago. and a new odyssey pc680mj
man, your luck is worse than mine :(
Well done is not supposed to be white/grey.
That is just a f**ked up burnt price of protein (I'm of even calling that shit meat)
Well done should be pink still, but cooked through.
Alvin, I have seen a lot of people eat scotch fillets bleu. The best part is the people that order bleu always have to make a big deal about it and ensure everyone knows.
Then when they get their meal and realise just how bad a bleu scotch is, there is no way they will ask for it to be cooked more. And they are very aware of the whole kitchen laughing at them
^ not sure if dig at me or dig at Mohsen. or both. probably both.
buggered on a Saturday night. might just play goldeneye: source and SWAT4. party time excellent.
PS miller's beer isn't too shabby or pricey. will buy again
That's shitty news :(
How are ya'll getting 27gb/month?
I'm on 1GB/month and average about 1.5GB/month... there's a bug in my plan where excess usage gets absorbed into my cap... so I need to his 3+GB before I actually start getting charged
Every time they call me, they're unable to offer me more than 1gb of data without increasing my monthly spend of $49 to something stupid like $60+, even with offers to recontract for 24 months if I had more data applied.
Want to stay with Telstra as well...
Telstra have a new offer. Get a new plan & for the first month they give you bonus 20gig on top of usual for first month to set up phone etc. well least that's how I assume people are getting lots of gig on phone plans
Guest
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
