Details?
It's a festival, in winter, at the Caribbean Gardens
Hamish knows
It's a Toyota (all makes) car show at Caribbean Gardens from 9am-1pm
what is with this forum? cant see most threads, keeps chucking the shits when i login.
I get the same issue
hahahaha, still plenty of people will think it does however
I'm having the same issue when logging in, every time gives me an error page after signing in..?
You aren't truly a Bogan until you miss your mortgage payments to cover the finance for it
But what if I paid cash :(, but more importantly what mortgage :'(
Ah well soon enough I guess, once I get off my ass and find something decent.
When are you buying a Maloo?
Never.. too slow..
Successful day at Sandown with a heap of SAU showing up, then today had Yum Cha at Knox and running around trying to find parts of fix the car so I can drive again
What did you guys get up to this weekend?
Guest
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
