Increase your premium, no free windscreen replacements, dodgy repairers, poor customer service, depreciating the value of the car every 12 months and refusal to replace parts with new when they are readily available.
Overall rating Justcars can go die in a fire. :down::down::down::down::down::down::down::down::down::down:
Yeah JustCars is a last resort. I have been with them for 5 years on 3rd party insurance, and they have the nerve to increase my premiums this year with no accident history / clean driving record. Surely a loyal customer with a clean record would cause the premiums to decrease? :\
Would much prefer Shannons, might try call a few different operators to see if one will approve me.
If you died earthing the frame of a light, you're probably retarded.
Was more along the lines of wiring it up to a plug and fixing the internal wiring and having no idea how the rest of it was put together by chinese factory slaves.
Was doing a bench test of them first before fixing them up around the roof of my garage, in case the drivers got hot and decided they wanted to start a fire and burn down the house.
I put in a complaint with the seller on ebay, they acted shocked and that it must be a faulty batch... Please check all the others and they'd follow it up with their supplier if there was an issue.
BS. There's not actually anywhere in there that the earth wire of that length would normally be mounted to... Instead it's looped back and tucked into the sheath.
Just start a new policy with them every year, that's what I did when I was full comp with them. Paid the same premium each year and same agreed value. My repairer did a flawless job actually used new parts too lol
Nah they don't see online policies. They don't even look at your policy until you make a claim with them, it's all automatic until then...as are the dodgy premium increases and decreased value. All based on predetermined percentages.
Start new policy the night your old policy expires. I rang them to complain about my premium going up and value going down, she said the best she could do for me was shave $50 off the premium. I said well a new policy will still be cheaper and a higher agreed value than that, so I should just start a new policy with you guys then? She agreed with me...
  • Like 1
And only a rookie would finish a steak meal on the veggies/side. Finish on the steak.
THIS...
gotta leave all teh best sides and the best bite of steak for the last bit
side tasted like shit, only ate the steak cos it cost me 38 bucks lol
I asked for med rare, assuming it would be like this ^ and got EASILY well done..
Edited by UNR33L
Guest
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
