Offfsets aside, clearance to the actual circular wall of the wheel was the issue with my 17's... Wouldn't have been a problem at all with 330mm rotors and the 8 pots... but I ended up getting sent 356mm and a different mounting bracket to suit.
The 17" AVS Model 6's DID fit onto the hub, and it DID spin (but it was grinding on the top and bottom of the calliper... and would definately be bad times especially once the rim flexed a bit on a bump or the calliper expanded)
Hey MohMoh, want to buy some sick JDM 17" rims from me?
Anyone ever have a look at an indicator/lights stalk on a 34? Is it shared with anything?
Looks to have 3 plugs. One is missing. Indicators don't work. Except there's nothing on the loom that's unplugged.
Only thing recently removed was a Turbo timer. The turbo timer had exactly 0 plugs involved with it at all.
What in the actual f**k.
Have a look if the warning button is stuck. Happened to me a few months ago and I was wondering why the indicators stopped working. Turns out the warning button was so ever slightly pressed down :)
..... warning button?
I should state that the hazards work, the fuse is not blown, and there's actually very much a missing plug connected to the stalk. There's 2 of three things connected there and I'm pretty certain if I had a working R34 I'd pull the plug out and see if indicators continued to work... because everything else on the stalk works except indicators ;)
It could be actually, that's what I'm not entirely sure of. I've found it hard to find out what the problem actually is, or an exact wiring diagram of how indicators are wired in.. it not being a fog light equipped car would explain why there's a missing plug and a loom which has no obvious disconnected plug attached to it...
Guest
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
