This is what the dyno correction method is meant to do... bring everything back to a baseline... But it never does...
So I never look too closely at the figures, just the shape of the graph compared to previous tunes on the same dyno.
My current tune is 243rwkw on an angry dyno, and it would be about 265rwkw on trents dyno, and maybe 255 on racepace judging from what I've seen from others... Either way, I'm happy with the good midrange I have now
  • Like 1
whats the difference between the 33 and 34 clutch?
the exedy HD 33 clutch is like $350 for the 33
and for the 34 its about $750???
wtf!? why the big price difference?
am I missing something here?
R33 clutch -
http://www.ebay.com.au/itm/Exedy-HD-Clutch-Kit-NISSAN-SKYLINE-R31-R32-R33-RB20-RB25-GTST-/181244122063?pt=AU_Car_Parts_Accessories&hash=item2a32fdd3cf&_uhb=1
R34 clutch -
http://www.ebay.com.au/itm/EXEDY-Heavy-Duty-Clutch-Kit-Nissan-Skyline-R34-GTT-RB25DET-NSK-7333HD-ER34-/121141141069?pt=AU_Car_Parts_Accessories&hash=item1c34931e4d&_uhb=1
R34 may be pull clutch, which is a more complicated and expensive thrust bearing setup.
apexi RSM installed
cannot wait to check out 0 to 100km/h in the evo
reckon its good for under 4 seconds?
I reckon you'd need about 260ahkw to pull that off
R34 is pull, I had a chromolloy fkywheel, didn't really feel much different ti stock one and really just made it a pig to drive at low speed, specially coupled with the libs laggy turbo and stupid tall gearing.
This.
Bombtrack had one in his 34 and it was shit. Sucks ass driving at low rpm and car didn't Rev any faster or perform any better than the stock flywheel
why is it always the high reading dynos that are wrong....whos to say the low ones aren't wrong?
thats my theory
also my NPC lightened flywheel was great ,its more a midweight than a light though...definately helped it rev up into the zone quicker.,..just made the throttle feel lighter in general and the engine more lively
Guest
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
