PowerFC Question...
Whats the best way to work out my current injector max duty cycle / headroom? I did a pull in 2nd to redline and it got to 75.8%... would 3rd or 4th be a better gear to test in?
Do all gears and pick the highest
4th and 5th might be a bit of a challenge
Or ask your tuner
Don't forget to account for hub kw when calculating power headroom
Looking to go E85 and currently hitting an estimated 75-80% on a BP98 tune via 550cc Nismos...
Any drop in injectors I should be going (to handle maybe 330kw on E85?) or should I be going top feeds?
Hamish was doing 320 with 555s on E85 tuned at Trents. That was close to, if not, maxed out
You can get Nismo 750cc side feeds (think they are red?) which drop in and would be plenty, amazingly not much more expensive than 555s, if at all
Or go IDs which everyone seems to rave about
Nismos seem to be able to handle ethanol fine
What would be the marked difference between 555s working fine and 750s not?
I have pulled a few sets out that tell me otherwise, covered in rust internally, and some covered in molasses at the tip. I prefer the single tip injectors for ethanol for this reason over the 4 hole pintle. Not saying they won't last years, but long term use, I wouldn't run them.
Highflowed sidefeeds are much worse, as the coating is cut through when they drill them.
Top feed injectors and rail kit doesn't cost much more than the Nismo's.
Well the skyline is perhaps soon to be a street drivable track car, so may as well go E85 for a bit of extra fun, see what ya'll raving about...
Will get a tune on E85 and see what I can get out of the current injectors, then upgrade them if needed... Current turbo probably won't even do 290 anyway...
How much would the estimated cost be on a rail and 6 of these Xspurt 1400's?
LOL @ restaurant game like you're a gangster.
im da bigst gangstor in da norfen sbuerbz
yeah no car ppl..
so the main ppl that run the SAu MS rounds own resturnat..
oh and Hatish, when he had a fun car...
they leave no time for anything unless theyre very well established and pretty much self sufficient,
that said, open one.
You would be surprised I think Simon, smaller turbo's respond to ethanol pretty well, if the tuner is willing to push it that hard.
PM me if you want some pricing, I will see what I can do for you.
No need to go past 300 on a street driven rear wheel Skyline anyway
A responsive 270 is killer and you'll get that with E85
An equally responsive 300 is better though
Depends what tyres you have I reckon. My setup was only just holding second when the tyres were new...I'd like to be able to put foot flat to the floor and not have to pull back on boost cause of wheelspin. 300 on E85 would be semi slicks and still break it in 2nd I reckon.
Guest
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25 The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
    • Nissan needs to forget about building SUVs in every size possible and bring back the damn Silvia/200sx duo to compete with the 86/brz. Maybe with the Honda type r motor pointing the right way
