fark that's bad
whats considerably worse than the holocaust is a flashing airbag light
autoelecs attempt and fail, recommend replace items that aren't broken (replaced anyway)
Nissan workshop manual is inconclusive and provides not-possible diagnostic results
google fails
sau fails
genocide is preferable
Did your airbags pop in your ditch kiss?
Or was the impact angle not right to trigger them?
No, it was at very low speed and hit it at the rear... and this is an entirely different car now..
Door button trick doesn't do anything. (wont go from 'user mode' to 'diagnostic mode')
Nissan say that it wont go from user mode to diagnostic mode if battery voltage is under 9V.
Battery voltage is 12.5v.
There's also a god damned mystery yellow plug behind where the head unit goes. There's nowhere to plug this in. Anyone? lol.
fark that's bad
google fails
sau fails
While I'm not sure about this holocaust humor
I had same problem with air bag light .. Do you have neons in the footwell? Or similar ?
Edited by alr33x
in all seriousness holocaust stuff isn't funny, its only funny because of how absurd and so on it is, and its that absurdity that is the funny part
anyhow,
Airbag wasn't triggering on car prior to it receiving my original engine and transmission and ECU's.
It is now. However, the SRS system is supposedly a self-contained system/unit with its own sensors, wires, and so on. Changing an engine shouldn't trigger it from what I can see going by the workshop manual.
Everything is that distinctive yellow, and there's a plug where the stock audio is, except this one is bright yellow. However it terminates short and there's nothing obvious to plug it into. Unsure if unfortunately coloured or god knows what.
Dunno if its even for the airbag, but its suspicious because nothing else was altered and the system won't even enter diagnostic mode to give me flashing lights to find out whats wrong with it all. Given this mystery plug is behind the head unit figured someone may have seen it before when they do something like... change a head unit which is pretty much done in every single skyline in australia
Well if it helps mine was flashing non stop auto elec tried looked everywhere turned out autobarn slightly snipped wire in passenger footwell that was causing the light on dash to flash so they fixed that and problem forever solved
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
