What was your SAU beef burger recipe again? Repost it.
1. obtain mince - highest quality you are willing to pay for
2. place mince on clingwrap being careful to keep the meat "strands" all in the same direction
3. roll meat into a cylinder approximately the size of the buns you intend to use
4. roll tightly so the clingwrap goes around the meat like 20 times (you can pinprick the clingwrap along the way to remove air)
5. find what you think is a sharp knife... make it sharper
6. slice meat into 1" thick slabs.
7. leave meat on cutting board until it is sitting at room temp (30 mins + is preferable)
8. heat a heavy based pan... then heat it some more.
9. season meat heavily with good salt and rub some oil on it.
10. place in pan. do not overcrowd pan as this will reduce the heat
11. the clingwrap will instantly shrink and you can remove it after a few seconds.
12. cook until crust develops on one side then flip gently. cook until meat starts to tighten only slightly
13. place cheese on meat and remove from heat. allow to rest for 5mins. during this time prep the rest of your burgers.
protips:
- bega super slices are awesome for american style burgers.
- breadtop make savory buns that are still loaded with sugar. they are small so you need a few.
- breadtop buns are so full of sugar they freeze and unfreeze like a charm
- you can make the meat rolls ahead of time.
- i usally keep a couple of meat rolls and packs of breatop buns in the freezer. If i want burgers all i have to do is remove and leave on the bench for a few hours then cook.
protips:
Awesome thanks. Sounds like a plan.
So no ingredients to the mince, onion, Worcestershire, mustard, garlic etc?
I feel my rolling skills will fail. Pics of said rolled cylinder?
There is one breadtop in all of w.a. Will hit it up haha.
never anything. just mince.
adding extra things means you have to over-work the protein in the meat and it becomes tougher.
Would love to but still scared by reliability
Would fking love to do RX7 LS1 conversion
Hmmm
Buy rx7, drive around til it pops and plonk a ls in.
Done.
Ah sounds good. Got any rolling tips before I turn it into a mess? (Leaving it open for a Ric response)
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
