Both can make you money just differently.
Capital growth gives you a big payout (minus capital gains tax) if the property shoots up in value.
Whereas high rental yield will pay off the mortgage repayment allowing you to borrow against it for another property etc. if the rentals are paying themselves off, eventually you'll have a steady stream of rental income trickling through as profit.
Yeah the second one sounds more like what I want... Can't see the value of the properties going up that dramatically any time soon.
What's the go with the 5 year stuff, buying a house withn 5 years old etc, for claiming depreciation or whatever...if you buy a 4 year old house, does that mean you only get a year of whatever that claim is...
Or you buy an old property, Reno it with your tradie contacts & either flip it or rent. If you flip it you will have to pay 40% tax on the profit else just rent it for a larger sum which puts it close to the mortgage repayment.
No idea in that space. Only have experience with old properties.
Anyone can buy a newish house and rent it. Put in the extra effort and buy a project to reno & get more rent for your buck.
cbf with renos at the moment... looking to buy something ready to rent... or consider building if that worked out more profitable somehow...
Buying off the plan can work out better however you'll have to wait until it's built. Buying a house and renting to a family could give a better rent:mortgage ratio than an inner-city apartment to a single person.
Speaking of houses, got any tips for good areas to buy an investment property Alex? Jess suggested Altona Meadows, anywhere else? Tarneit any good?
Yeh depends what your after - I wouldn't go altona meadows myself i think seabrook has potential can get a good size block with a house on it for under $400k surrounded by suburbs that similar blocks cost $300k+ alone
With so many people trying/doing exactly the same thing (buy, rent out, negative gear, buy again) where will the market go? The rental market is flooded with houses at the moment, a lot of them overpriced because people need the money to pay off the mortgage.
If rent is so much cheaper in the CBD than the burbs, i think rental prices are going to spread from the cbd outwards and shrink purely because there are so many investment properties & town houses popping up. Especially when a lot of older folks are trying desperately to make up for their lack of super. That plus foreign money snapping up properties... Somethings gotta give in the next few years.
I reckon every 3rd-4th house i inspected last month had a for lease sign before even the For Sale sign had been taken down. It doesnt look good because you know the owners havent done much/anything to the house and are possibly going to be tighter than a ducks butt when it comes to costs.
lol @ the block first world problems ... My owners would be doing back flips to get 10k, 40k over reserve! Shit even to get reserve!
101%
mopst of my properties that go to auction do not hit reserve.
Altona North, right on the border of Williamstowm/Newport has a few bargains left over your side if you want to play the capital gains game...
This is hard to achieve without extensive work done by yourself (then you have to value your own time)... Even interest only
Hi jezza
How's the band going
Thought the same.... lol'd
Strongly advise not to buy off the plan apartments / land etc
This.
Have you tried to drive in and out of Seabrook? It takes me almost half an hour to drive from Altona Meadows to Seabrook Blvd after work and it's like 5km...
tried newish burger joint in Huntingdale: Burgled.
burgers are under $15 and were pretty tasty.
Had a japanese-style? fried chicken burger with asian slaw and wasabi aioli. $11. quality sweet roll. do recommend.
next SAU monthly meet. they open late and huntingdale is dead after hours. plenty of parking.
Guest
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
