I think when you saw me it was at alvina's house. That was from cat, not hayfever
Stupid cats. Toby knows my pain
Nah it was up at Skyline nationals
I was copping it too, fkin dusty cabin
Sif mow on a high pollen day lol
You've almost sold me on a Gloria
You should see some its cool hidden stuff. Bawler as f**k.
Cons:
Auto only.
Second hand parts (is there such a thing?)
ECU is in same league as M35 stagea; no one wants to touch them (except stagea has cult following to push for some aftermarket options)
But at least its hella cheaper than a chaser (300kgs lighter too)
lol Jono I remember your hayfever
Feelin it today too bro, nearly a box of tissues down
Nose was runny for whole 3 hours of mowing today. Not the thick runny, the watery runny.
Abalon A eyedrops, best thing ever.
i managed to rid myself of hay fever for good. used to get it to the point i couldn't open my eyes...
can't remember who, but someone told me to go to the local market, and buy some locally made honey. have a teaspoon each morning(on toast etc) and within about 2 weeks i never got it again..
apparently because the local honey has local polin in it, it helps your body build an immunity..
maybe I'm wrong.. but it seemed to work.. haven't had hay fever for about 4 years now..
Cons:
Auto only.
Plenty of VIP bodykits, JIC do coilovers for them, bunch of cool exhausts. That's about it.
i didnt say there wasnt aftermarket support for cosmetics... (but feel free to link some exhausts)
just getting stuff like AFMs or ECUs or even coilpacks without paying a fortune could be problematic. at least nissan still make most parts for them.
almost put on a better show than the 787b at WTAC
https://www.facebook.com/video.php?v=10152477296201234&set=o.676423219103325&type=2&theater
Cons:
Auto only.
are you trying to say that a Y34 is 300kg lighter than a JZX100?
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
