Na I hit up some soft shell tacos from salsas... Should have got the spicy ones, the plain beef needs a bit more kick...
Would totally demolish that burger over a few hours though... Apparently to get it, I'd need to fly to Chihuahua Mexico, so its a bit out of my price range.
Sell the evo, it's all the rage these days.
  • Like 1
should have gone to a dick filled taco truck. f**king ass hats.
Or go to Captain America's / Misty's
loling at some of your replies Ham
lol'ing at them
Nick that scotch has gone back up to $500, hope you got your bottle!
Yeah got one for my dad and myself, should've mentioned it was a 24 hour deal
Your mum did
m.youjizz.com
I'll just leave this here...
10407142_10152848532716840_1679943444470
simple is better brah
Dis
Ultimately the patty makes or breaks the burger
Everything else is an improver or a detractor
Which is why Ham and I recommend old mate Jamie's patties
Seriously though, they're pretty farkin nice - capsicum, paprika, onion, hints of chilli, some other shit. Almost Mexican tasting. Dollop some Nandos pepper sauce on top and finish with tasty cheese in a lightly toasted fresh bun...so good
Add salad if you prefer the company of men
on the simple wagon here..
tho now and then then going a smashed patty a double cheese burger is good.
8Bit is a good example of this.
other than one seemingly minor thing, they cut the bun too near the top, so the top falls apart cut that bad boy in the middle and that would be a near perfect burger.
I ate at 8 BIT last night and thought it was pretty damn tasty. Had the chicken burger with coleslaw and the Footscray station doughnut milkshake.
Some nut case ordered a burger with 2 chicken patties and 2 beef patties while I was there. Looked like a cardiac arrest in a bun...
My mate ate there last night.
Saw your car
nohomo nostalker
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
