Anyone on here using plazmaman products? Had a mate running a fmic on his xr6t and couldn't speak any higher of it. Definetly thinking of saving for a few months and getting a fmic with their plenum.
Saving for a few months, what are they made of gold? Get a Blitz CS and stick with the standard plenum...
Rails? for seats???
yeh.. $350 a pair is the cheapest ive seen making my own lol
agree with bird brains... the plazmaman plenums are only good for BIG top end power larger TB's.. and to achieve this the runners have to be the perfect length, and ID.. i would say that alot of the names without the "blitz greddy hks etc" names would just be generic lengths because it 'fits'..
you sure you want to make your own?
in a car accident id hate to see poor seat rails fail and the seats come out of the car
im not making my own as such.. but making an adapter plate to switch from recaro to bride.. ill still use the recaro rails.
i'll beleive this after you bring it to the next dyno day ;)
380 at the rears seem too much and I don't trust the guys at motor mag, or whatever the mag link you posted was to even know the difference between flywheel and rearwheel kw's let alone report accurately on it
I will :) seriously look it up if you don't believe it already a few dyno vids on youtube
Don't know why people doubt the power figures, the engines are over 2 times the displacement of an rb26, and even standard NA falcon/holden/toyota six cyls make more power than stock rb25det's. Add the fact that the factory power figures are usually understated, and it's not hard to make big power with minimal mods..
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
