IIRC, that was during the fuel/energy crisis when severe emissions regulations were brought in - everything was hardcore detuned/restricted because that was the most cost effective way to meet the regulations. They also put a bunch of small engines in their large cars. If you look at American engines of similar size from the 60s, or late 70s, the power is a very different story!
Nonetheless, torque was more important than power from these engines as they were coupled with tall gears/diffs and even with limited power the bigger engines still pulled respectable quarter mile times. It also didn't stop people from modifying them to remove the restrictive nature of the engine.
I just find it surprising the most common (and successful) motors at world time attack are 20 years old lol
As much as i wish people could manipulate and change modern engines the same way people do 90's engines... Its just not heading that way. Even if there was a large customer base, theyre getting harder to crack.
The only real modern engine i can think of that still gets massive modification treatment is the LS series, but the base motor has been around for ages
Actually I don;t think it due to not being able to tune the egine, look at the R35 for example.
I think a fair bit of it how heavy the cars ended up getting.
now that they are looking at efficient cars getting lighter again so I think the next generation will be looked at for TA again.
but think about getting around a corner,
Evo 8 is 1320 kg,
R35 1740
S15 1200
with a limit to the weight reduction based on a % factor you still end up with a very heavy car and weight is the bane of racing.
What kind of engines are you talking about?
RB's, SR's and 4G63's?
These days when its all about cost cutting efficiency, fuel economy and emissions, there's hardly any Over-Engineering which allows you to make 2-3x standard power on an engine, simply by adding boltons...
^exactly...? Over-engineering is certainly cost cutting from a tuning perspective, but look at subaru... Many parts are like glass but theres demand and therefore solid replacements. Just most of the base motors are still over 20years old lol.
But theres no V8's, and few 6-cylinders even. Rotories are really only still in the picture because their fans are purists
Guest
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
