anyone know how to time yourself at an untimed event?
mates doing sandown. untimed event.
theres probably an app you can get for your smartphone, not sure how accurate or reliable it would be though.
could always have a mounted go pro and check the video later at a certain spot for times? again bit of a guess & hassle but would give you a pretty close idea..
Download RaceChrono for Android...
Pair it with an external 10hz Bluetooth GPS like a Qstarz BT-Q818XT stuck to the top of the windsheild if you want anything resembling accuracy (as a phones inbuild gps isn't going to be able to update fast enough, especially down low in the car (pocket or glovebox or center console))
Add Sandown to the list of "My Tracks"
hit "Start Session", then drive.
+ 1
Its accurate to within tenths of the actual natsoft times.
I also mount the phone onto the dash so i can see live sector and laptimes
Have it in the car and concentrate on the stopwatch while doing 200 down the main straight...
What?
It's no different to quick look at the gauges while doing 200.
  • Like 1
Yeah I'd rather not click a stop start stopwatch when on a race track.
What?
Again, it's no different to switching lights/indicators while doing 200+ km/h anywhere really. Won't cause you to lose control and heading for armco barrier or concrete wall.
What?
I darno mate
You dont have a great track record :/
  • Like 1
You land vaginas need to ride a bike at 250+ for some perspective
Or watch youtube footage of nutters doing that speed.
Or watch crazy goat lovers doing 250+ in highway between Istanbul and Ankara, while being followed by couple of BMWs driven like its stolen.
I darno mate
Therefore you'll be fine with a $2 stopwatch. Cos you're not me.
Edited by Count Grantleyish
I'm not saying it can't be done it's just not preferred
And I would prefer not to do it, same as every other track day car, haven't seen one driver go out on a hot lap and time himself with a stopwatch in the events I have been too
  • Like 1
Guest
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
