Because 380 is HUGE power, not just big power ;)
Its also a massive % increase for just a tune
Lol have you been in a boss model yet? My manager has one and they absolutely hammer.. Didn't actually believe ford brought out such a powerful car from factory in AUS
380rwkw without mods? :mellow:
what do they weigh?
About 1800, maybe a bit less which is expected I guess for a big car.. got about 300kgs on my old GTR :O.. still do a tune and your in 11s.
Other vids online to back this up as well / all info on forums etc
Standard boost just drops off so much
They go alright:
This ones got a catback and a tune, nothing else
I met a bloke the other day selling a Callaway Corvette..90k if anyones interested..still left hook though
11 sec in stock trim and 200mph+ top speed
much the same as this one
http://www.youtube.com/watch?v=x8HyT4d7Kzc
Enjoy 380rwkw on pos stock tyres/suspension/brakes
When you bringing it to a meet Leigh?
Obviously upgrade the 245s, and will be doing brembos / suspension down the track as well
Whenever the next meet is !
Saving for a few months, what are they made of gold? Get a Blitz CS and stick with the standard plenum...
Lol studying full time+part time wages=not a lot of cashola.
Yeah I've read that that upgrading the plenum on a standard turbo isn't really worth it as I won't see any real gains but by doing it now with a FMIC it means I won't have to do it down the track and it'll support future mods better (ie. upgraded turbo). What I liked about the plazmaman plenum was that it retained the standard factory runners. Essentially I'm not after a car that's a dyno king rather a quick car with some good midrange torque.
interesting leigh!
the car was running 118's @ full weight, anyone know enough about boring/pointless/homo drag racing to derive a rwkw figure from that?
FWIW i ran consistent 119's with 325rwkw @ 1350kg
Going by that post, you do not need a plenum upgrade and are only wasting your money if you get one. And it doesn't sound like you have a big disposable income so why bother?
If you're not after a dyne king, rather a fast street car, turbos like a gt-rs are where you'd be looking, and you don't need an aftermarket plenum for that.
If you ever decide to get a turbo that does warrant a plenum upgrade, thats when you buy one...
interesting leigh!
What about that fluke 190mph pass Ham? No need to be modest
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
