Is your bike regoed still dezz?
Nope
Sorry brah
Think the time to be subtle would have been if we had just broken up lol
I would've thought Monica was refferring to your ex's ability to ride...
+1 for PI taking way more skill on a bike, more balls too...
car has
walbro 255lph pump
stock injectors
stock rail.
wouldnt take any more ignition timing and detonated when more boost was added. so gonn get some cam gears and hopefully solve that problem.
current wish list is z32s, id1000s, cam gears and some brand new coil packs.
I'm not sure why you think Cam Gears is going to fix your car not wanting anymore timing, theres other issues at hand.
Also I told you don't get Z32's fagget jesussss.
  • Like 1
haha should be good once we work out why it keeps bitching out when we add more boost.
is e85 really worth it? i have to drive 15-20 mins to get it....
Does United on Mahoneys Rd still have E85?
inb4 more VWL people own bikes than Skylines
I so want a bike but just cannot justify if
When my daily gets under 5K a year put on it hard to see a reason to get a bike to run around in
Duke street fighter hnnng
reply to msg qt.
Doing Broadford on the 14th, CSS at PI on the 15th...Might try get another PI track day in before thailand, then try get a few more in in Jan when I get back, before going back to work in Feb
Looks like I'm booking in the 19th of December with a couple mates, bring it on
If all goes well I'll likely be doing Jan 5th after that
/pielinesaustralia
did lol
https://www.facebook.com/events/293399480871242/
Jesus... $350 for an untimed Sandown track day... Hell, my last PI day was only $210...
Remember this up a driver dynamics run day
So they gotta pay for birds...
But in all seriousness they have pro drivers for driver training eg v8 super car drivers
much much less cars
So you get 20 min per hour
Much better than 3 sessions as wrx gave most of the day to the porka club
  • Like 1
Bikes don't need justification, most people who own them ride a few times a year. Everyone got their reason for riding...for me it's the best shot of adrenaline to get you out of a slump or a shitty day. Unless you buy new or euro, they don't depreciate as quick as cars and anything under 10k almost hardly depreciates unless you whack a lot of km on it.
I'll be honest though, most people I know with a bike, myself included, are always in two minds...do I keep it or do I sell it. The latter when they aren't riding it, but when they are, they're thinking why the f**k would I get rid of this.
Guest
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
