Well.... To actually have full grip they'd need to be at about 30psi hot... which would mean near 20psi cold / normal driving...
If you're running at 30psi cold... once they actually get up to temp then they'll be 42psi.
Note that "Hot" does not mean "I've done a quick burnout on them before a launch"
You're going to have an absolute ball on them if you dial them in properly on the track.
no he's not.... it's MOHSEN
you KNOW he only bought a PAIR and he has frikken ling longs on the fronts right?
Snowy Mountains 1000 over the weekend.
fastests car R32 GTR.
2nd fastest..
Jeep Gran Cheerokee
Damn
http://racing.natsoft.com.au/635860535/object_915454.82N/Result?8
That's fkin hilarious
What an awesome driver
At the same time, DECA has been won by FWD hatchbacks hasn't it?
got lang longs.
cheaper than ling longs.
nah, its got some bridgestones.
steers alright. does need ALOT of work aligning things etc now though. can feel everything wrong with it now, felt nothing with 225s and stretch lol
Lol if that's the case, dat under steer will be so bad
reverse everywhere
Oh my bad, it's a 1000 metre sprint, I thought it was a really short course like a wang
yeah long and straight, whould hate to try and get that puppy to turn!
(more so if you find pics the squat it has on launch makes me think still quitre soft suspension.
re DECA, I "think" a Type R integra won 2WD but not outright once.
that be it tho.
Moh you need to switch em around and have happy fun sliding times like me
What's the retail on AD08s these days anyway? inb4 more than you can afford pal
edit: http://www.tractiontyres.com.au/pdfs/a048_clearance_a4flyer-web.pdf
dem 19 inch feels :(
Edited by UNR33L
Thought about switching to 18's?
How small do they look on the titanic?
they look terrible, some guy on ford forums did it and wow lol.
standard they come out with 19s for a reason I guess
Guest
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
