https://m.facebook.com/profile.php?id=100004506918385&fref=ts
Pretty sad reading all that; why would a guy do that to his family and friends
What are we reading?
Also for someone that doesn't have facebook you sure know alot that going on in it :P
Also curious where his accomplices are at this time...no doubt has them as friends on Facebook and there are a few motorcyclists in his friends list. I could take a judgemental guess based on display pics, but that would be...judgemental.
The plot thickens..
Next step: go to funeral. Make sure everyone sees you ride in on loud motorbike. Keep tire iron hidden in leather jacket. Then time to get judgemental.
"Judgement Day"
Funeral action scene ensues, may or may not include mini gun inside the coffin.
3am on the morning i fly out, boss says need you at leongatha for 2 weeks, can you go there on monday but first swing by Bald Hills wind farm near Ballarat on your way.
So much for R&R.
That calls for christmas bonus. Hope i still get a chance to rego the gloria, fark having to reschedule with vicroads before christmas
is Huy electrical engineer? one of my contacts put this up yesterday: "Urgent - Seeking a Electrical Graduate Engineer for 6-8 weeks worth of work in Brisbane doing take off's for an Electrical Contractor based in Brisbane - Start ASAP | Please call 0408 138 011"
Interesting the day the bike was stolen she posts a photo of her wearing a motorbike helmet.
Yes I noticed this
I keep forgetting the date it was stolen and focusing on the date it was found
Mechanical...if it bleeds, he can fix it
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
