Yes I noticed this
I keep forgetting the date it was stolen and focusing on the date it was found
cops should contact her and find out who his bike mates were etc.. but fat chance of police doing any actual work I guess
Actually she probably knows exactly who helped him steal the bike, I wonder if she'd give up the names given what's happened now..
Edited by UNR33L
Fat chance of her doing that
I'm guessing the acquaintances are keeping very quiet, probably even from family and friends
There's a few motorcyclists on his friends list, one rides a different model R1, one works at Peter Stevens in Dandenong, could have had a leg in it
If I was very wealthy I would buy it, put Toyota badges on it and track it.
Then I would collect all the 34R fanboy tears in a vial, put an atomizer on top and use it to mace their security guard at the next meet.
LMAO!
what if i told you, im looking into buying an R34 R.....
but only a bayside blue one on superlaps so i can join all the other bayside blue douche bag owners.
  • Like 1
Careful Leroy, a lot of those have conditions where you're only to drive to workshops and compliance / Vic Roads
yes im aware.
however i have the distinct advantage of having numberplates, so ill fit them to make it less... likely to be pulled over?
just need to figure out what screw size is required. i could never bloody figure it out on the pulsar
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
