ok new speakers ordered
jbl gto
628 6 1/2 2 ways coaxial for front
938 6x9 3 waycoaxial for rear.
so the reason for doing this, is the central locking has crapped itself in the drivers door. can still use the key but the central will not lock or unlock.
ford charge 300ish to fix.
the parts to fix it in a rebuild kit as it a very very common thing is 15ish.
so going to do both doors so the other is sorted, and figured I might as well replace the crappy factory speakers whilst the door card off.
the the rears on the ute are easy to get to so why not.
so for the rebuild kit for both doors.
mounting brackets to change from crappy 5x7 front and rear to decent sizes
body loom plugs for the speakers to make it easier to put in.
plus some bonnet struts as mine are shagged..
less than ford to fix one door.
and gives me something to do in an afternoon over Christmas with a beer
and should sound beter too
  • Like 1
Will def give a go
Smokin Barry's food van is awesome and much the same food
I told em I wanted something with a lot of meat and no vegetables and they said yes sir, you're our kind of guy
yeah just avoid the prawns with rice, dunno why the wife ordered it, anyone would think prawns and bbq sauce is an odd combo lol
Would recommend some sound deadening pads to stick on the inside of the door skin behind the speakers, if the skins are pretty thin and would like to vibrate when the music is playing.
Made a big difference in the skyline when I did mine.
Cos I don't like labor?
I think he was referring to your post containing words that we all know and love, but just not making any sense due to the order they were placed in.
Starting to get over seeing Liberty Walk doing only expensive cars....
I wanna see some cheap shit get the treatment... like an R32 / c33 or even something crazy cheap like a cressy
Guest
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
