they take too long to sync, most only check their time once a day, and when I go through so many time zones it too long.
for travel I use a pebble steel smart watch that syncs real time to my phone.
and phones sync of the local network so I'm always correct
https://getpebble.com/pebble_steel
haha nothing wrong with fashion.
discussion point: if a workplace culture condones the use of designer tie-clips, this may allude to the point that business-attire could be a factor on the judgement of colleauges. (excluding colleagues who deal with external clients etc)
May not be an issue in your space as mentioned but could be in other places.
Have always worn company issued uniforms for both Site & office along so never had the issue.
However where ones uniform is prescribed, the stand-out factor is usually the flashiest watch.
More people teased me about my Tiffany tie clip than admired me for it lol
Helps that I'm good at my job and not a terrible bloke though
  • Like 1
sorry for taking an interest in my car....
ps; ive driven just over 3000kms since i got it in may this year
I've driven 3000kms since last week
You're all missing the main point here, that Ric was told not to dress sexy at work but continues to spit in the face of authority.
And all that dress for the job you want shit just goes to show how shallow your corporate shit holes are...
  • Like 4
at telstra we don't have a set uniform or corporate standard
flexible working
yes but you have to work for telstra...could be worst...teletech...
Slacks, dress shoes and a collar are the only prerequisite at mine
Can have whatever facial hair etc. polo tops etc.
our office is collar and no ripped/offensive clothes.
but when customer facing need to dress well,
that said after getting suits tailored properly, they much more comfortable than anything except tracky pants
The way you present yourself is an extension of your personality.
Chefs are a great example. You never see a scummy motherf**ker working in a fine dining kitchen putting up good food, and you never see a kempt ass motherf**ker working in a shithole on lygon st.
I base part of my hiring on appearance and always will.
If you can't be f**ked dressing well I don't want you in my office/kitchen/wherever representing me
I didn't say anything about dressing like a homeless kunt, but if the fact you don't wear/can't afford a $3000 suit means you don't get a promotion over the sexy Ric looking mother f**ker at your work, who isn't as good at your job as you are, then your corporate world can smoke me.
  • Like 2
Guest
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
