Anything over $40 and its not going to be terrible... I prefer in-ear phones for better sound isolation. Instantly equals better sound
Gloria has been registered 12 hours and phase one is almost complete already lol. Car is almost "cool". Still needs a few things
chopped springs, gestalt virouge and a cyber bodykit?
actually you pretty close
something like:
http://www.dicksmith.com.au/earphones-headphones/sennheiser-stereo-headphone-dsau-c9921
would find on jb but for some reason cannot access there website from here
Dat price doe jeezus!
Only really need a pair for Saturday lol. nfi when I'll need to use em again.
Looks like them
"Strong Bass Response"
Either you're lying or JB/Sennheiser are lying
agreed, i use them at work and they ok for background noise
but yeah nothing compared to wired ones
http://www.productreview.com.au/p/sennheiser-rs-120.html
Sound clear but a little tinny and lacking depth/base.
I also found the bass levels to be quite acceptable...source dependent.
Very ordinary bass level
that said i went from HD450's to these, so big diff in quality, but the old ones got trashed.
yeah i paid less than that for them.
great for planes and data centers for removing white noise
Get sennheiser HD25s.. Hamish used them for over a zillion sweaty drug fuelled club gigs in the 90s and they still work perfectly today when he rides the train at 6:30am bla bla bla
You forgot that I used them skiing as well
I bet you were listening to Huey Lewis And The News while skiing
Their early work was a little too new wave for my tastes, but when Sports came out in '83, I think they really came into their own, commercially and artistically. The whole album has a clear, crisp sound, and a new sheen of consummate professionalism that really gives the songs a big boost. He's been compared to Elvis Costello, but I think Huey has a far more bitter, cynical sense of humor.
  • Like 3
you also forgot to add that I have the original German made ones from the 90's not the lower quality Irish made ones available post 2002
Guest
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
