Shure for earphones. I always thought sennheiser were a bit overpriced or over bassy. But still shit on Bose.
Start spending anything north of $200 for anything other than sound cancellation and MP3's dont so the headphones justice.
Their early work was a little too new wave for my tastes, but when Sports came out in '83, I think they really came into their own, commercially and artistically. The whole album has a clear, crisp sound, and a new sheen of consummate professionalism that really gives the songs a big boost. He's been compared to Elvis Costello, but I think Huey has a far more bitter, cynical sense of humor.
who needs a Mic? you just plug your headphones in the mic jack
I remember plugging microphones into headphone jacks when I was younger...you did get a tiny bit of sound out of them
Hey guys, had some problems with the Evo over the past few days... can I bounce some ideas off you to help diagnose?
2 days ago the head unit (Aftermarket JVC Double Din Touch screen) just went blank and restarted as I was driving home.
1 day ago on my 50 minute drive home it happened 3-4 times, most of the time after I'd been sitting at a set of lights for a while, literally the second I let out of clutch and started moving forwards. So at this point I was thinking "Maybe a loose power connection at the back of the head unit?", but it always started back up immediately by itself.
This morning I was cruising along eastlink at a hundred, Head unit went off like all the times before but when it started up (and was playing the radio just fine), but there was a message on the screen saying "Power off unit". A few seconds after I noticed that the engine gave a shudder and lost power for a split second, a few reds came on the dash (engine shutdown) and then it restarted itself with momentum and being in gear. The Check engine light stayed on until I pulled over, turned the car off and back on. Drove fine with no loss of power for the remaining 20 minutes of the drive.
Head unit went off once more when I was pulling into the carpark at work.
Thoughts?
if I mysteriously go missing from the forums you know the Evo blew up
Son of a bitch, you shouldn't have said that!
Thoughts?
first thought
bad earthing?
  • Like 1
Where though, and why has it popped up only in the past few days?
Engine bay has a full high quality earthing kit which connects about 10 different places together, inc the battery itself.
Think I'll dig up the multimeter here at work and check battery and alternator voltages, though that'd surely show up with the battery light on the dash.
Perhaps an arc from a short made the ECU temporarily confused, or read the CAS wrong, and that caused a misfire or shutdown?
inb4 "Oh it does that... one of the reasons I sold it"
  • Like 1
well... it's been nice chatting with you all these last 19,562 posts...
  • Like 2
bolts come loose, just start checking connections.
after that check connections and current on alternator
then battery test
def sounds electrical tho
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
