I've never had a steak go cold on me, apart from the 1kg challenge I did...
What if you're no good at cooking steak...?
And if you go to a good steak restaurant /good restaurant in general, your steak will be juicy
Well true it doesn't go cold, but a normal steak doesn't stay anywhere as hot as stone grill. It's like that first awesome bite of steak, but over and over again. Old man travels across town just for it haha
Ain't really cooking it yourself anyway, cause it cooks quick enough that you're pretty much just cutting pieces from the block as they cook; it's hard to screw up unless you're a real slow eater, but can always pull steak off the stone I guess.
Haven't even taken delivery.... just signed contract.. should have it in a week.
it's not exactly a 300rwkw R33... but it is far more convenient for driving kids around which now make up some 99.27% of my driving
lol @ single mum.
is $160 fair price for A/C re-gas? (from scratch, not top-up)
bit tasty, but its summer so 30% increase.
check out cranbourne auto elec. ihe was a top bloke, charged me 180 for a service, few orings, labour for repair and gas on wrx.
Tony have you got the dyno read out from your 380rwkw with a 3" exhaust? Boss has told me in the past that it's almost impossible to see over 330kw with a 3" exhaust.
Yeah it was on Trents dyno, did a drop of the exhaust and no restriction
Its a jjr 3 inch dump and cat, then get slightly bigger to the muffler
Refitting for that new style refrigerant as well?
Y34 should already be R134a, even 33's are already. 32 etc need to be converted from R12 doe.
AC in the new RS is f**king awesome. Have receipts for regass done in 97 and then again in 2011. On the way back home from shitney had to keep turning it off cus it was too cold.
  • Like 1
  • Like 1
aye is pvc pipe okay? Ill use the proper plumbers cement.
Guest
    • They're so beautiful 😍
    • Early last week, I became concerned that the car was feeling....slow. Most of my driving is commuting to/from work and there are few opportunities to get up it and convincingly make boost/power. It drives in vacuum almost all the time. But when you do occasionally get an opportunity, and.... it takes a little longer to start making power, and then there's not as much as you'd expect, and then you run out of road anyway and have to bottle out - it can be hard to be convinced that there's something wrong. But by the end of the week I was pretty convinced. Made an effort to get a decent test run. Took bloody forever to come up on boost and when it did it would only make about 50 kPa of pressure. There was no black smoke, no noise of a boost or exhaust leak, no evidence anywhere of an intercooler hose clamp being sloppy enough to let air escape. So.... not that sort of problem. Brainstorming led to thinking that the boost controller's solenoid might have failed in some way. No active boost control would just give wastegate pressure, which I was more or less getting, and the laggy behaviour could just be "normal" shitty boost response from an uncontrolled highflow. But a little extra 3rd party brainstorming led to the thought that the actuator circlip might have jumped off leaving me with a bluetooth wastegate. So, on Friday, off comes the stock heatshield (which is an annoying enough job on its own) to reveal - yup. WG is wide open. And.... it won't come back. It is jammed in the dump. Put the rod back on with a new circlip and tried driving it to get it hot in the hope that the capture was from thermal effects having been blown into the dump when hot and since cooled. Nope. Won't move, even with screwdriver mediated force when hot. Ran out of time to play. Came back to it yesterday. Unbolted the dump. Was lying under it with the dump jammed up against my guts undoing the bottom 2 bolts. Got them most of the way out and gave the dump a serious heave. It didn't noticeably move, but there was a satisfying "plink" noise from up to. Shuffle out and sure enough, gate is now closed. Nevermind that there was still the better part of an hour after that required to put it all back together. f**ken cars.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
