so went to MiColour to discuss painting and fitting of body kit for gloria... learnt some things about the do's and don'ts of fibreglass body panels.
but now its time to weigh up whether its worth the cost... can anyone recommend a place worth chatting to? im prepared to pay for quality work, but in Mick's words "How long is a piece of string?" can go very very long when trying to make possibly warped fibreglass "fit" nicely. (im preparing for the worst, hopefully it should be pretty good)
on a side note, S14 at micolour getting the whole sha bang-a-bang has some serious money put into it. like so serious i couldnt believe its to be used a street car only. on a S14 that had hit a pole on the rear quarter. the fenders were made by Mick and will fit 11" wide tyres once some tubbing was done.
  • Like 2
DT Panels is another option.
some place near Clayton. cant remember the name. maybe PK Panels in Huntingdale?
was hoping to find an alternative to DT Panels.
I swear Odie has been to a place a while ago that was good (other than Micolour)
Nope... Only bodywork that I've had done is getting my passenger door replaced after a woman backed her car out of her driveway into it while it was parked.
Insurance job via JCI and went to the lowest bidder (a place on Princes Highway Springvale). Paint was well matched (though, its a flat white, so not that hard really) though everything else was horrible... Snapped a few of the door card panel clips and didn't replace them when swapping it onto the new door, power window is a bit flakey and only works 90% of the time, power mirror hasn't worked since, window was so out of alignment that letting the door swing shut would make it stop with 10cm to go...
JCI said to call the workshop and book it back in for them to fix it. Workshop said to call JCI and book it back in for them to fix it (ETA a week), I said "Hell no you're not getting it back for another week" and fixed a bunch of it myself. Mirror is still dead in the water...
Saw that s13 when I had some working getting done out there and it was a little insane! Kinda want it :P
A45 AMG is pretty quick though!
In saying that 230kw on e85 on the r34GTR
Probably similar power to weight to the tuned stock turbo'd R34 GTT which makes 200rwkw at around 1,400kgs
But dat r34 gtr doe #race #rb26 #gloves #e85 #race day # race helmet #security guards #fastest car # most exclusive car
Yeah this part I don't really understand. I had low comp cylinder 1 in my 32R, and stock with 14psi on 100octane it made 250rwkw... On E85 that 34 should be making 300rwkw at least. I don't think a hub dyno would have robbed it of 70kw... Something's not right there!
  • Like 1
All 34R qualified mechanics must be SAS reg trained former NASA lead engineers and have obtained at least certificate 2 in crowd control / security operations to work on the vehicles
Which is why it's so hard to find a place who can get you more than 230kw at the wheels
Bahahaha 230kw, seriously? I feel sorry for the guy's hired wife and kids
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
