neo head, 26 bottom end. 26 manifolds, best of both worlds.
That involves more effort... I'm talking just getting a s2 25 AWD from a stagea and dumping it in as is.
Will cost $1k + labour and most importantly look like a 25 hence providing epic fanboi butthurt
Mike likes to over complicate things.
Need to smash the mantra of KISS into his head.
We don't think it's done any other damage, can't find remnants anywhere else. No bearing material floating around and bottom end APPEARS fine from a wiggle and inspection.
Pulled out onto riversdale road and gave it a little bit in first gear, went to change at about 5k rpm, looked down mid change and saw light was on and gauge was at 0 so turned it off and pulled over.
I have a feeling that pulling out and crossing over but still driving parallel with the tram tracks is what did it, all the wheels having different amounts of grip. Started raining 5 minutes after I pulled over too just my luck! It's a standard pump, getting replaced with an N1. I know it's not an amazing replacement but I'm not spending a grand on a Tomei pump, and this brand new versus an almost 20 year old standard pump, should be fine!
It's also getting a sump baffle extension thingy, kinda like the Tomei style with trap doors, only its an extension welded onto the standard baffle.
Oh and did I mention -7s! Hnnngggg
I'm about a second or two slower than you on most tracks, I don't know how to drive yet though...
Will be repairing intake manifold gasket and switching to E85 to squash these detonation problems before the next day.
Got a wedding on the 31st of Jan, so no Philip Island WRX Round 1 for me... :( Was hoping for a late summer PI
Guest
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
    • I could see someone trying this to save money on oil changes.
