I have 4 cans.
I'd budget 1 x 20L Jerrycan of fuel each way to Winton or PI.
Which leaves me with only 80L of usable fuel for on the track. May need to invest in a few more Jerrys...
Still a bit concerned about fuel sitting for so long once I switch to 85... when I was filling with P100, I'd just use the remaining fuel to fill the daily over the next 2 weeks.
Yeah Winton is quite a bit more distance for me
PI is only about 120kms. So 2/3rds a tank for travels than the rest of racing
I wont be doing winton till I get some sort of flex fuel happening from Trent
I've driven to PI from the west on E85 with only 3 jerry's n raced all day. Fill up in Cranbourne, race all day and then stop at Cranbourne again on the way home.
That's good to know :thumbsup:
I find I use much more at winton as you get so much more track time.
plus sandown as you have the throttler open so long each lap.
PI you only get 3-4 sessions normally so not as bad,
calder you get bored after 2 sessions and go home ;)
I have 4 cans.
chuck evo on e85 too. simple.
I carry my laptop with me and when I run out of E85 with no E servos in range, just switch to a rich 98 tune when there's about 5-10 litres left. Runs on this mix fine, can even give it a boot.
Flex is for poor planning.
this!
that PI will not be in the MS championship as a bunch of us will be unable to attend.
but I know the guys are working on dates as we speak, with some big improvements over last year.
Any ideas on when & where the first one will be?
PI ride days are like $285 this year, quit your bitching
We need to hire MICA Paramedics, Recovery Crew etc...
You guys need to pay for a cleanup truck as well to remove face chunks from the track.
http://mypolice.qld.gov.au/rockhampton/2015/01/08/police-warn-motorists-not-block-speed-cameras-man-charged-rockhampton/
Well which is it? "High Visibility Policing is an effective deterrent for speedsters" or "Camera cars are now able to disguise themselves and hide (for their own safety)"
Guest
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
