What sort of times and top speed do you get up to on your motorbike?
I've seen around 250 on my speedo down the front straight, I'll have GPS speed next time though so I'll get back to you after my trackday there on the 27th. Should be able to get more speed with my latest mods, but will be cloesr to topping out so it'll be interesting, hopefully doesn't hit the limiter down the straight.
Times, my best so far was a ~2:05 I think... I take a few seconds off every time I go usually, but obviously that'll slow down as I get under 2 minutes.. My quickest mate does a 1:40-1:41, another around the 1:47 mark and then a few in the 1:55 region...then a few slower than me and one around my pace, at Broadford at least..
Stock fuel lines are fine in skylines
Might not even need pump and injectors as your turbo is only small anyway
Currently have a Walbro 400L E85 Compatible pump, and 550cc injectors and new fuel line in the engine bay... I've heard that you should get the proper E85 line for inside the tank though, since the inside of most lines can handle it, but the rubber on the outside generally doesn't last when its submerged.
Chris made it make a happy 278rwkw on 98 (then pulled back for track safety), and then the intake manifold gasket pushing out the side made it want to detonate on the straights at Rexmas. So going to fix that up and chuck some E85 at it to see how it likes it, either the turbo will taper off or injectors will max out. Hoping for the magical 300 so I don't start breaking other things while I'm out there.
ouch. Why not throw in a remax steel while youre at it?
For the $330 for the gears + $400 for the pump I may as well just get a better pump. On top of that car needs to be done by the end of the week so couldn't wait around for the gears.
It'll be fine, N1's only really break if it's an aftermarket balancer, or you get really unlucky.
  • Like 1
250km/h is bloody quick!
A mate of mine just came back from PI; his first time there and second track day...lodged a 2:17 for the day. I imagine he'll be cutting off a few seconds ala dezz with the next visit. Jelly cause I was supposed to go with him :(
As for ethanol, all you need is a fuel pump and injectors that can deliver it fast enough, and a tune / whatever mods to support your power.
That's it. The rest is a wank. Uncomplicated science that people - usually those who aren't running the stuff - make into a big ol' Poirot murder mystery.
I'm all about that E85, 2 years now, no treble.
  • Like 2
Speedos lose their accuracy above a certain speed; it's unlikely anyone looking at a speedo 200+ down the main straight of PI is actually doing that speed. GPS only way to tell.
I think it's easier for cars to come out of that last sweeper onto the main straight with more speed already built up.
Plus 600s die in the ass above 200, top out around 260-270.
aye ric
http://www.ebay.com.au/itm/Vl-turbo-/141531162467?pt=AU_Cars&hash=item20f3ea2763
lets go halfies, slam it on its guts, with a fat as f**k dose, just cruise around and flutter bitches.
aye ric
That's quite nice.
I had the chance to put BioFuel lines in my car today with the engine out, opted not too because you're right, it's not needed!!
aye ric
Not gonna lie, it looks like my first car hnnngg..
Guest
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
