just bare in mind here fellas, the gps hardware shit you use on your phone, is a once calibrated piece of junk.
use a seperate designed for piece of equipmunk, and make sure its calibrated.
also, enviroment plays a huge part in gps signal. so dont just rely on that.
not saying whats above is wrong, just giving you all the info.
don;t use the gpn on the phone,
I use an external 10Hz GPS reciver liked to racechrono on android.
the lap times are withing .1 of a second of the track ones, (think it more due to the start stop line in racechrono is not the same as the beam they use for our track days)
so think the results are fairly accurate.
assumed that but thought would clarify.
when I used the GPS jsut on the phone times were more than a sec out from lap times, the external GPS as mentioned brought it down to sub .1 so I'm happy for the time being.
  • Like 1
If you need to be accurate to less than 1/10 of a second for recreational racing... you need to get a life lol
If you want an accurate representation of how well a different line through a corner effects your time, then having an accurate GPS is pretty important.
I use a 10Hz Bluetooth module as well, stuck to the top of my windscreen, because I have my phone wrapped up in my centre console and GPS Reception when you're inside a big metal cage isn't ideal.
Lap times can be within a 0.1 seconds... however things like top speeds and corner speeds go absolutely retarded if you've got a poor signal and it thinks your bouncing all over the track.
What if you drive a BNR34
Them you don't need to be timed as that is below you. You already know you are the fastest. Even faster than the RWD guys going faster than you
  • Like 1
Guest
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
