I don't really see the problem.
Yeah what Martin, I don't see the problem with that either, plenty of people run Harnesses in their standard GTR seats.. I wear dirt bike gloves cos it's all I have cos my hands sweat like a mad man.
later in the day used on the track as well.
we just laughed that he arrived at the start of the day with harness and gloves on.
oh and had plugged in the seat belt in and then sat on it with the harness on so the light did not blink the whole way up..
so this guy seems to manage without gloves...
obviously he is only in some puny rally car and not an R34 GTR hence being able to drive without gloves... but still...
  • Like 1
Not sure what he has more of, grip or balls
Grant wouldn't last 50 metres...too much Armco
Love it when his navigator tells him not to be a hero at the end
We could do cool races like that on the great ocean road if Victoria wasn't the diaper state of faggotry
Interview was funny, American Sniper didn't really live up to the trailer for me...
good games for PS4?
never really watched the trailers etc so had nothing to expect, for what it was not knowing anything was good.
But just saw a trailer before and yeah can see how it leads up more than what it gives
Used to play prince of persia flat out..mad game
Farkin guillotines and falling shelves
Was rad when he landed on spikes, such a gnarly death
And that coward sword guy who wouldn't come after you until you turned your back on him, had to lure him into the next screen
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
