"hi, i have a bench top meat slicer i want to sell"
how old and what make?
"dunno"
can you send us some pictures of it?
"nah my phone doesnt have any credit, i can bring it past"
no thanks.
Toby if I'm renting out a room to a mate, should I just get cash off him for tax purposes or is direct deposit into my account okay? does it make any difference come tax time?
Birds - when you get the GTR brah?
Edited by UNR33L
whats the price of 91 atm?
when I left it was 1:13 so I would expect E85 to be sub 1$ by now...When ti was first out it was advertises at 25c less than 91..what happened?
julia guilard/tony abbott
I has it
Same thing that happened with LPG I imagine. More people use, more demand = can afford to push up the price. They would have made it cheap as shit to get people using it and now they have a decent customer base, someone has to pay for all the new pumps.
But 98 used to be 10 cents a litre more than 91, and the difference keeps going up. So as long as E85 stays lower than 98, proportionate to the extra fuel usage, I'm happy. Even if a little more expensive to run it's worth it.
United recently took over a servo 2km down the road from my house and put an E85 pump in - so handy! Used to have to fill up 3km away from my work.
Filled up the excel the other day, think 91 was like 1.09 at safeway petrol... Seems to have dropped a fair bit since I went to Thailand, then again I don't really look at the price when filling up so maybe I just didn't notice it
lpg is not the best example, it has stayed similar 50-60 c jsut when fuel prices when up it became less economical. and now prices dropping it's dropping at same rate.
expected the same for E85.
considering how much more you go though bet there not many of those flex fuel commodores using it atm.
EDIT:
just went and checked Holden site, seems for VF they dropped E85 support, so guess that answers that one,.
EDIT:
I disagree on the LPG, it may be proportional but back a few years ago during the LPG boom when every man and his dog were doing conversions for $500, the price of the stuff jumped up with little to no change to petrol prices. I was filling up at 40 cents a litre or less and out of nowhere the shit skyrocketed...I put it down to demand.
demand will always bump prices agreed.
not sure the demand is there for E85 tho, not a huge amount of cars running it.
other than the FE commo, who supports it from factory?
also with prices going up makes you wonder how long it sitting in tanks for.
Don't get me wrong, I'm not against E85, when I get around to changing injectors will be moving to it.
just thought it was cheaper is all.
Must be the aftermarket using it - that or united are seriously committed to marketing it, because they keep popping up new servos with E85 / installing tanks.
Alvin may like to correct me, but I don't think e85 goes off / loses it's octane in tanks as fast as say 98 would.
They would be sealed to prevent water build up, and alcohol/ethanol doesn't really go off over time?
(in some cases improves!)
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
