Pics? And price?
no pics yet.
drove it. nice zippy car, 370GT
Surprisingly small! its like one of those audi sport back things.
feels punchy. uncle things its a monster. haha
he paid in the low 30s landed and complied
Alvin may like to correct me, but I don't think e85 goes off / loses it's octane in tanks as fast as say 98 would.
They would be sealed to prevent water build up, and alcohol/ethanol doesn't really go off over time?
(in some cases improves!)
assuming perfect seal, same same, the problem with etOH based fuels is it absorbs water, and above a certain percentage, it splits. not funny so yeah dont use old fuel.
with petrol, octane falls and the additives gum up in the presence of oxygen. much of the same really.
  • Like 1
that's quiet interesting when according to the Gov most petrol stations have water in their tanks already
http://www.fairtrading.nsw.gov.au/ftw/Consumers/Buying_goods/Petrol.page#Water_in_petrol
so one has to hope these are sealed a bit better.
Didn't you have meisters Pat? These look the same?
Still have the meisters; look similar but different
custom 2pc 32 GTR rims, stepped to 17"
EXACTLY what I have been trying to make Mohsen get.
so f**king boss
+1
I want but custom :(
2 cool to walk.
birds theres a built 26, ready for a head and some hangons on facey for 4500
In qld? If so it's on eBay too
Not a fan of the gear he's used in it, $350 forged pistons etc.
$4.5k for just a built bottom ends seems alot
yes, and i'd want someone to go over it before i whack it in the car... not gonna trust nobody. especially for RB26, when if a hairdresser does a bad job it not only makes a vocal complaint but then pulls out a gun and shoots everybody inside.
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
