Tightarse option.
Used 32 crank 120-150
Ebay Wide oil pump drive collar $90
Collar fitment/grub screw clean/crack test ~$300 total.
Spensive option.
New R34 crank, ~$800 overnight parts from Japan
Tightarse option.
Spensive option.
but if you overnight parts from Japan it will decimate all
how did that go?
pump replaced and all good?
All good!! Replaced sump baffle with trap doors and put some -7s on. Made 285kw on it's first run, stock ECU on 15psi. Cannot complain one bit!
Will be getting it flex fuel tuned before PI and hopefully do I dunno... maybe 320kw on E85 with stock injectors? Don't know yet!
Yeah but in all seriousness doe, 1.50s is very very quick for a non serious racer isn't it? I'm not super up to date on what is fast and what isn't at Phillip Island.
Might install an oil cooler next week to ensure I can even last an entire lap without getting too hot!
i did 1:57 first time out, street tyres 180ish RWKW
RSR all round
maybe 3 track days that year as the engine let go and got rebuilt
mid 50ish is what I call good for a 200ish RWD
53 or better with the bit of extra grip should be about right
richo and madden now into mid 40's but your not getting close to that.
Imma take it easy and hang around the 2:10 range lol
Guest
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
