standard 33 GTR seat failure.
came into a left 270 and as I smashed it into 1st and ripped the handbrake the seatback let go and I ended up in the back
LOL!
that happened in a VL i was driving. didnt rip the handbrake, just turned a corner and planted it
the worst by far was that one when it BUCKETED down and that guy was there in the elfin clubman v8...
Poor dude had the worst day... freezing in the morning with no roof (he wore his helmet on the drive up) and then flooded on the way home (was using said helmet to pail water out whilst driving)
I was running 235 NT05's and driving at ~80 tops on the fwy as the car would just aquaplane into other lanes randomly...
yeah after sau nats in shep (the best one, when i finally met the one they call dezz, and jonoe and i realised that birds sleeps like hes dead)
driving back home with -6deg camber was sketchy as f**k.
had a mate who knows what hes doing when it comes to wiring come and help tuck the headlight wires, relocate the front body harness.
f**k me.
nissan really couldnt be f**ked with these cars..
that was the guy that was on R888 semi's and found out there was no drain plug in the car...apparently drilled one when he got home.
think i recall driving behind you and seeing your car all over the place
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
