I don't remember meeting you mohsen, can't have left much of an impression.
And don't be ridiculous, no one would post for likes if you died.
I remember the meeting
Something about Mohsen getting his cousins and friends over the other side of the racetrack to beat up Dezz
Dezz saying he'll drop them after he drops Moh
Awkwardness for a couple of minutes
Then sunburn
rofl. and yeah, jonoe almost dying
pat, do not to 26.
it took me an hour to get the bottom afm pipe onto the afm.
to 25/30
dont be a bitch.
i dont remember meeting you at AS nickos.
but i do remember froffin your car on edgars road when i was a young thug muzzin my way through thommo (kid who peddaled everywhere because too young)
also, anyone missing a silver fiat punto?
why do i have people calling up and describing the item but not giving me the make and model number
"hi im calling about the dishwasher you have listed on your website under dishwashers, incase you forgot they wash dishes, are approx 700x700x1500mm in dimensions and resemble large rectangles, i would like a price on this piece of machinery" - exagheration
WHAT f**kING MAKE AND BRAND?
Spent the weekend on the skyrine...
Oil temp sensor installed with thanks to Scotty and his lathe / tapping skills.
Little coolant line that goes behind the block replaced (had previously split and been "fixed" with a straight barb because it was too hard to access)
Intake Middle Gasket replaced with Plazmaman replacement
Wideband gauge installed, still need to punch a hole in the floor with a rubber bung to run the sensor through to my front pipe
Then E85 Tune and Phillip Island on the 8th.
Everything is coming up milhouse!
Guest
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
