Either that GTR is exxy for what it is or I got a massive bargain
Not nearly as many mods and same engine situation for 5k more
Was black a factory colour? I didn't think it was but looks like the same black as mine
yeah black was, but rarer than the 'rare' midnight purple!
why not t51r 26/30 build? do et
Edited by UNR33L
How, I don't have Facebook and I'm too lazy to find other methods
http://www.importmonster.com.au/contact
cos that would be hard.
"Also will be parting a slightly damaged R33 GT-R for anyone chasing bits. Front right was hit, didn't look like much but the rail is damaged. Engine's mint, gearbox, diff, brembos, factory wheels etc etc Front bumper, driver's guard and headlight damaged. Rest of car is straight as."
QM1 White - 6048 [s1, S2, S3]
KL0 Spark Silver - 2256 [s1]
LP2 Midnight Purple - 2222 [s1, S2, S3]
KR4 Sonic Silver - 1860 [s2, S3]
KH3 Black 1052 [s1, S2, S3]
KN6 Dark Grey Pearl - 592 [s1, S2, S3]
BN6 Deep Marine Blue - 407 [s1, S2, S3]
AN0 Super Clear Red - 259 (special order color) [s1]
BT2 Champion Blue - 177 [s2]
AR1 Super Clear Red II/Nismo Red - 139 (special order color) [s2, S3]
GV1 Black Pearl - 19 (the very last V-spec built was this color) [bNR34 color]
AR2 Active Red/Carmine Red - 12 [bNR34 color]
Quite deceptive too, as midnight purple does not look it's best at midnight and marine blue GTRs don't work particularly well underwater
Clear red also isn't THAT clear
Sooo many R33 Boat comments...no idea where to start.
  • Like 1
americans had it right in the 70;s
MOPAR 1970 paint list:
Mopar s 1970 model year High Impact exterior colors:
(option code - Dodge/Chrysler-Plymouth)
FC7 - Plum Crazy Metallic/In Violet Metallic (nicknamed Statutory Grape )
FJ5 - Sublime/Lime Light
FJ6 - Green Go/Sassy Grass Green
EK2 - Go Mango/Vitamin "C" Orange
FM3 - Panther Pink/Moulon Rouge
V2 - Hemi Orange/Tor Red
FY1 - Top Banana/Lemon Twist.
  • Like 1
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
