serious talk time fellas.
have you all ever gotten so over everything you feel like you are working to achieve nothing, like no goals, no aspirations. just working
and before anyone says find a new profession, i like this job. it pay well. but everything else is meh.
wake up, shower, work, relax, fap, shower, sleep.
i cant even be f**ked chasing chicks anymore, and my temper is getting shorter and shorter. what the f**k.
in seriousness
http://www.beyondblue.org.au/
or on a slightly lighter note
http://www.mantherapy.org.au/
  • Like 1
Make some lifestyle changes moh
well no make some positive lifestyle changes.
if the lifestyle change you make is smoking vast quantities of ICE..prob not going to help.
The Man therapys site has some good ideas on where you need to look and suggestions to help.
all from the context of a man cave.
(it's run by Beyond blue as well)
Man therapies was enjoyable.
you smoke? eating well-ish?
person ive been hanging with lately has some issues and i think a lot has to do with diet and not having enough energy to do things.
lost my shit hahah
i smoke, have cut down the crap food intake. really just cook at home.
like last night, i declined a kebab and had the arab bean sprouts i had cooked lol.
i hardly drink now, like a stubbie or two at the very most.
ill sus those websites out
its really strange because one minute ive got everything under control, next minute im losing it and feeling like smashing something.
have another ct scan in 3 months. doctors thought the cyst might have something to do with it.
lost my shit hahah
how about your realise your not some little bitch, and man the f**k up.
life is shit. its hard and doenst get easier unless you win the motherf**king lottery.
if you need a hug, come get one, then im gonna smash you in the other eye socket, cos thats waht life does.
الكثير شقيق الحب
Where do you see yourself lacking in the above picture? Work on balancing all 5 if you have focused too much on the others.
It's why Ive moved back to Melbourne & getting ready for 4hr flight to Perth. Exit row to my self for free.
Seriously Moh, you had your well paying job given to you on a platter, hence the complete lack of appreciation for how good you have it.
If you had to work to be where you are you would have an appreciation for it and a sense of fulfillment about life.
Now quit sooking and sell some f**king ovens you spoilt shit.
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
