Buy Investment property.
Then buy another one.
Buy jetski.
Have so much f**kin money that you have to retire at 40.
Thats what everyone else in aus is doing, right?
Every Joe Shmoe wanting to own an investment prop. The quality of houses going up today is purely driven by lowest build price for maximum rental return.
Sale Prices aren't relative either as rental income always a factor.
/1st home buyer problems
  • Like 1
+1
For the last 10-15 years basic houses in Melb have been fkn terrible quality that will show in 5-10 years, all those kit homes and duplicates/clones in the western suburbs especially.
  • Like 1
My to-do list before I go back to work next Wednesday is small, but not at all decreasing. Procrastination is stong
Buy dishwasher
install headunit in excel
track day saturday
track day tuesday
The last 2 of those will get done, but that's probably about it
Anyone know a towie in east / south east who is good with lowered cars / does cheap or cash jobs?
Jack from Citywide towing on 0419877437
towed most of the SAu motorsport ppl at some point, plus grant a couple times.
used to do a bunch of track days in his 33 gtr so he know how to get them on and off the tray.
only issue is when he tries to buy the car off you, eh grant....
Sounds like my man
Ta
Gonna see what the limits are with them... who knows, turbo could max out first...
No point going and spending a grand on injectors and rail if what I've got is fine.
i was gonna go e85 on my 550's for the wrx, but i feels there is not enough duty left in em.
last thing you want is sitting at 95% +.....
you have adj fpr just to give em a bump?
Was at 278rwkw (racepace) on 98, I think approx 70% duty after pulled back to safe track tune...
Here's hoping for a safe tune that I can run with for more than 1 track day without popping something again.
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
