17s not good enough?
not with the brakes planning
i think aaron managed to fit those on a 14 martin.
with 295's?
it all good going to have some fun with the car this year.
start lining up some parts to fix the cosmetic issues and make go faster at same time.
good time to be alive.
Was thinking the same thing... going to be 2 streets away on Saturday, so was going to pick them up then... wait a second...
Subtle visit to RacePace
It's handy living two streets away from both of them
Couldn't have picked a better suburb for modifying cars
Really not that subtle...
Heaps of other stuff in the area as well, paint shops, bolt shops, total tools, bursons, etc
Things that I need to travel 20 minutes to get to, when I realise I need something at 4:30pm on a Sunday
  • Like 1
one ring to rule them all..
well all the money
i just dont get why you need to get an engagement ring AND a wedding ring...
sisters engagement party tonight. says on the invitation "No gifts please". go to my parentals... "you better get them a gift!" why? "cause your family"
weddings pls. farkin gives permission to be retarded and charge money for it. its like GTR tax cept that shit is fo'eva
  • Like 1
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
