Out of 300 people, only one couple gave me a non cash present. It was a photo frame..... uwotm8
I bet out of the 300 people you'll remember the photoframe couple the most lol
People invite way too many f**king people to weddings is the problem, they're self indulgent bullshit at its finest.
They are the selfie of events.
Too expensive to invite heaps of people, close family and friends will be enough for me
This!
  • Like 3
We used the engagement party as a way to weed out ppl
As we did it at Amy folks home we could invite lots and stlill keep it chea
If ppl did not rsvp or worse rsvp they were coming and then not turn up with out contacting they were off the wedding invite list
Got numbers down so quick was great
  • Like 4
Pop Quiz:
Tony - What did I get you for your wedding gift?
Everyone Else - What should I have gotten him that would have been the most perfect present ever and made Lynnie hate me for life?
Ric gonna be remembered for a long time and that vase will shine up instead of being spent on a holiday or the next iPhone.
Hopefully! Will check if it's visible in their home when they invite me around for dinner
Pop Quiz:
is the answer a stripper?
Birds, I need to hire you for breakfast dem eggs looked maaad.
also, dat vl @ 1 min, & 5:45 running an easy 9 moh you needa get one - 800hp min
Edited by UNR33L
Yeh I agree but is what it is, gifts are fine but getting shit u don't want blows for all we know rics vase is an annoyance they have to keep and pull out in the event he comes over.
cash has been the norm for certain cultures for ages
not with the brakes planning
with 295's?
it all good going to have some fun with the car this year.
start lining up some parts to fix the cosmetic issues and make go faster at same time.
good time to be alive.
I got 275 on 10.5" under there, and that was with a fairly wide offset (+22) I flared the guards enough to easily get 295 under there. If you want to be safe, get a higher offset. If I remember correctly there was plenty of strut clearance
what you running front?
that's my big concern, rear I ahve to do something wild anyhow as the guard is fked
front I have some options...
I had 9.5" +12
I can't remember the tyre size though. Fronts had heaps of room. My offsets were too low, should've gone a little higher.
Hollandaise or the deconstructed with bacon bits and garlic bread?
I demand further clarification regarding this hollandaise of which you speak.
Didst thou purchase said hollandaise from ye olde supermarket like a common peasant or didst thou appease thine hollandaise gods and maketh same?
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
