I find it a little scary that your life can be messed with, for better or worse, simply because of what a computer screen displays...with very difficult or non-existent avenues for getting it changed. It's not corruption proof, but it's fairly repeal proof.
Reminds me of that movie The Net.
GTR registered
No RWC required
Guy did have a weird look on his face when he walked out to see it on Jack's tow truck. Also saw Russell there coincidentally.
Noice!
stick it to the man, man.
saw a strange car on the road today. an older man, driving a de-badge toyota or some sort... i suspect a AE95 JDM sedan. Stock everything except a towel across the back seats. It was beyond pristine. the rear mud guards were like brand new, the paint put most show'n'shiners to shame. the chrome on the (stock?) dual exhausts looked fresh.
Did someone really do a full restoration on what im pretty sure was a late-80's corolla?
Had classic (not historic) white text on black numberplates. the old skool ones before green.
haha did you pull up in the inspection bay with the car on the tow truck? Did they need to check VIN etc?
Yep
I said it has a bad engine knock and I'm taking it to my mechanic before driving it on the road, which is true. He just confirmed the chassis and engine numbers (spent ages trying to read the RB26 engine number, lulz were had), then we swapped the numberplates over and nek minut registered.
Yep
We have customers who get the works done on their cars, spend big money on it, THEN go to vicroads to get it registered... Very ballsy!!
Where's your car off to now?
You guys if Chris can give me a date to bring it down - can you go ask him now lol?
haha, lowered it off the tow truck or he climbed up?
Took it off and drove into inspection bay to show that it can be driven, albeit very loudly. Many looks from people before we took it off and even more looks when we started it up lol
  • Like 1
Ain't at work today, am debating whether or not to go to the doctors in an hour that's how much I don't want to move :\
you young people have no apprication of hard work, when I was your age I hade to hop to work in the snow as I could only afford 1 sock per year.
then work 20 hours for 1$ a day (thus the saying of another day another dollar) b4 starting my second job as a moving target for the police force.
and I never called in sick.
amidoingitright?
  • Like 1
amidoingitright?
almost.
Better than being trapped inside...
Must take a look at mine as well... keeps getting stuck halfway down... the bolt that tightens onto the motor shaft keeps working itself free and slipping. Time for some locktight me thinks
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
