I did the same a couple years ago, the instructor didn't let me go past 4k rpm. As soon as boost starts to kick in, he was like change gears! Started yelling at me to change gears when I didn't lol.
Loved it when they took drove around the back track though.
Think this largely depends on the instructor you get and how many laps you sign up for.
First 8 laps of mine were in the evo and the instructor was making me change into 4th at 60 lol, just to learn the ropes of 4WD slides...but even he didn't mind me redlining 3rd down the straight.
Second 8 laps in the STI was with another instructor and he was telling me to go faster and faster. I asked if they could put me in with him for the hot lap for this reason, then told him I'd requested him specifically. I reckon he let his ego take over cause fk me there were some hairy moments involving trees and concrete tubes. Was scared but calm cause I felt he had total control and I have no idea how he made the car do what it did. Amazing driving ability that I could never dream of having. Many of the instructors compete in ARC, so it's pretty close to the real thing when you're in that passenger seat!!!
  • Like 2
have done said hotlap. Gunning it down the straight next to the fence was unreal.
  • Like 1
Drove a lambo lp570 ferarri 458 and jag xkr in the las vegas canyons when I was in the U.S was sick as :D best thing is you do it solo so much fun. Ferarri was the best car, lambo was like a full on track car brakes you had to smash, steering and gearbox was like bashing you against the hard seats lol
drove the first 3:
World-Class-Driving-Exotic-Experience1.j
Edited by UNR33L
  • Like 1
Ok. I can check em out if you want to remove them. Or just grab some 1000's, retune and enjoy e85.
What else are you going to spend all that FIFO cash on...
The effort of removing manifold to get to injectors is the same as plonking in 1000's haha
Re fifo cash; lots of jetski's
Guest
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
