No idea man.
There is a brake joint in the second side street of grange rd next to Moorabbin DFO that always had stock and does good prices. Used to have SAU Vic discount (still might)
Sorry can't remember the name ATM
Article Heading should just be "Chinese Teen is an idiot" and the Article Contents should be "That it all"
Did lol @
By then, her son, who was identified only as "Little Wang" had already smuggled a kitchen knife from their home and snuck out.
Depends if their Cancellation Department is actually a Retention department or not.
If they ask why you're leaving, say that you've already signed up with another provider.
If they ask why you're moving providers, say that you don't wish to disclose the reason.
If they say that they need a reason for their form, say you don't give a set of meat flaps about their form
Saw the stills from the latest ISIS video (cm before the flames hit him) and fkn wow. Barbaric shit.
Looks like Jordan is now executing all 6 ISIS prisoners they are holding at dawn now.
Video has surprisingly good production value, looks more like a college arthouse short
Massive step up from the 8mm terrorists of yesteryear
And yeah, these guys are very quickly gonna end up with the world on their doorstep
Guy at work showed me the video, we both said the same thing that it looked fake / dat dere CGI and effects :\
edit: Maybe it was because I saw it on a small phone screen.
Edited by UNR33L
Yeah something about it didn't quite look real and the guy didn't thrash about nearly as much as I thought he would have / compared to other imolation videos I've seen...but then what do I know. The flames looked a bit excessive.
Or just change provider, don't tell old ISP shit. Month later get final peanuts bill and done.
Guest
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
