Labors was way more juicy. For extra lols they brought back the guy they axed in the first place
Abbott might not be ideal but the public need to wake up to the need for budget cuts or we gonna end up like Greece. Heck Id take a labor gov provided they take some action to reverse the debt trend - but we know that'll never happen they are like women - spenders
Something something Turnbull likely.. something something fighter jets. Who's asleep?
This is the problem with younger generations they don't actually see the importance of who and how the country is run..
I blame the education system.
wtb evo x
Marry Toby.
^^ wasn't pickin on ya man just a generic statement and it's sadly quite accurate young people have no idea about politics God half of them think when the government pays its like its the governments own money as if it's a income generating business not the people's money
If Turnbull gets back in it's practically the same scenario... remember he WAS pushed out by Abbot. Albeit in opposition but it's errily similar.
What really f**ks me off is that at half a mill a year we will most likely be paying for 4 pm's that either weren't voted in or were ditched. That's $2m a year for life for a bunch of flogs that couldn't lead their way out of a wet paper bag.
Also you do realise that the whole budget surplus thing is not actually as important as it is made out to be by the LNP right? It's mostly just their current election strategy. Sure it's preferable but all it really means is our projected spend is less than our projected income. Even surplus budgets when actioned can still leave the country in debt and often do not actually result in cessation of borrowing, (especially when we buy EXTRA shiny fighter jets)
What really matters is that we see infrastructure projects implemented, economic growth driven and those that need it helped while working towards a balanced budget in the future (when the economy is better positioned.)
There is NO need to have it sorted by 2018, other than for the purposes of re-election.
What we need is a very centre right government. Unfortunately that is just not an option at ptesent.
so went to refuel car on freeway.
fire brigrade blocking road.
seems some tourists in their rental van put diesel in instead of petrol, so on exit to station at freeway,
just out and think lets drain the tank that will fix it, 100 Litres of diesel all over the road...
van still stranded on on-ramp to freeway as well.
The jets thing is a lefty go to option to pick on libs the fact is they were allocated for like a decade ago.. And national security isn't a bad idea imo.
you can't deny we are living in the age of entitlement and welfare and its completely unsustainable in its present state and set to only worsen.
budget may not need fixing in the next two years but action needs taking now not when we are further down the drain with no way out
The jets were budgeted for years ago and both parties were committed... but then we went and ordered 58 more.... it's a LOT of money that could have been better appropriated.
Yes it's an age of entitlement, no one can doubt that, but we need to have welfare, it's simply not avoidable
I agree we need to look into fixing the budget, but the approach has been deplorable and has also all but guaranteed a Labor government will return very shortly.
Australia is doomed anyways.
Iron ore has dropped to $60/tonne from $180/tonne highs
http://www.dailyreckoning.com.au/category/resources/metals-minerals/iron-ore-1/
Once a $30billion revenue stream for Australia has been wiped.
Buckle up, it's going to be a bumpy ride.
The policy's to fix the budget have t been that bad.. Students should pay interest on hecs loans the loop holes and outstanding balance is ridiculous
Paying $7 to see a doctor? No problem with that either
Despite what labor and the greens want us to believe there simply isn't enough rich people / corporations to slug more taxes on to cover the bill. Middle & low income will always feel the pinch as they are the most dependent and largest tax base and as much as they whinge figures showed after rebates / deductions they were taking out more than they put in...
ok this is getting out of control..
think we should put him down for his own good:
Mohsen Younes
snapped the lower control arm mount off the subframe, am I better off going gtr subby or having the standard one reinforced?
Guest
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
