am after an amateur/start-up photographer to take photos at an upcoming birthday party.
Not after any professional or a film studio production team (ala Toby's wedding)
Anyone know someone looking to make some coin for a few hours of photos? Sat 14th Feb - location: Buleen
I cant be bothered taking photos myself, rather drink instead.
thnx
My friend does this on the side from doing scorptecs marketing pics and graphics:
https://www.facebook.com/trot.shots?ref=br_tf
Dunno can message him, tell him you know me and see if he can do for reasonable cost possibly?
Interesting to note that ALL health funds share the costs of the most expensive claims under the current arrangement.
Allegedly this is the reason it's so expensive regardless who you go with.
thnx
Jamie?
http://m.smh.com.au/business/why-private-health-insurance-is-so-expensive-and-what-can-be-done-about-it-20150122-12vi1y.html
The chief executive of listed fund nib, Mark Fitzgibbon, proposed three solutions to ease the pain: encouraging greater take-up of insurance by young people; increasing collaboration between insurers and healthcare providers; and reconsidering risk equalisation - the policy that shares the costs of the industry's most expensive customers among all funds.
You forgot potato scallops
Potato cakes with extra salt from Dandenong Oasis swimming pool. The good ol' days
The Noble park swimming pool was always sketchy. Heard people would put razor blades in the tube slide.
/school rumours
  • Like 1
you too could be gay like that leigh.
supra's wheel of choice is often the Work SSR/meisters. mainly because supras look shit with just about any wheels. its almost more rare to see a supra with factory kit than with leftover aids kits from Y2K. doesnt matter what kit, wheels, spoiler, bonnet or lights you put on a supra, it will always look like an obese peanut on wheels next to an MA70 supra
Custom body kit.. Never heard of abflug?
Ahhh YES! I do remember actually agesss ago downloading supra videos on dialup lol
okay.jpg :(
  • Like 1
Despite being lighter, faster and more focused towards performance than the "Am I a luxury coupe or a sports car?" X70 :P
Saw Aston Martin / Jag looking car accelerate rapidly out of driveway in Wantirna...closer inspection it's a Tesla Model S 85
Didn't get a chance to run him, but managed to leave him behind as he followed me out of a slip lane. Silent as a dead man
Keep an eye out for him Leigh lol
Guest
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
