The heat / rain / RDO stuff is fair. Helps that I like you though..
I wonder how many of those people sacked face that outcome because the employer can't afford the wages that result from union bully tactics (or if they are genuine flogs who hide behind the union and try to blend in with the decent blokes like dezz)
Considering what our companies charge us out at, I don't think it's an issue. People get hired and fired with the rise and fall in work. It's the nature of the industry, the union doesn't stop it happening, they can't, they just see that the proper notice is given etc
For example, at the moment Downer and Stowe have the lionshare of the work...Their guys get paid the same we do obviously.
My company has most of the work at the airport, but those jobs are expected to finish mid year. Obviously there's always more work to be won at the airport, but it's not a given that the contractor their currently will get the next job...
As my companies jobs finish, and if they don't win some more to keep the current amount of sparkies on the books, people will be made redundant (around 100 have already been made redundant in the 3.5 years I've been there) Some get re-hired, some are no good and don't come back, and others were just unlucky to be the one to go, and will more than likely get a job with whoever has most of the work at the time.
It's pretty rare that someone in my industry works for one company their whole career
So I thought I might do some trolling in the news.com.au facebook site to keep the left/right balance... Holy shit! I couldn't bring myself to reply to the epic stupid... ALL OF THE STUPID.
Admittedly I jumped into the deep end by going for an article about the Bali 2, but I thought it would be at least in actual English...
Never before have I seen the word "use" (meaning for some reason the plural of you) written so frequently... Not to mention "U" and "R" etc etc.
The pointlessly vitriolic commenters and holier than thou Internet tough guy's were virtually the only commenters with a reasonable point either for our against being made maybe once per 10 replies.
It was just bogan australia at it's worst... The kind of people that treat ACA as a reputable news source.
I thought the age was bad...
It made the age comments seem like a freaking pulitzer prize contest!
When you consider this is who they aim their articles at... well you know where I'm going with this...
Guest
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
