Edit
I went to a bank auction for a house. Got passed in & went in to negotiate as I was only bidder.
Realestate didn't want to drop from reserve price, has now listed as private sale for $50k more than reserve price.
I don't understand that logic.
Bank probably getting shafted in all of this.
which ones?
Audio-Technica ANC9's
http://www.scorptec.com.au/product/Headphones/Wired/46443-ATH-ANC9
They work as advertised, fine when listening to music, plenty of range (and bass if the song requires it), comfortable on my head, quality build, replaceable ear padding foam bits, can disconnect the cable at the headphone itself if you want just the noise cancelling, single AAA battery (have been through a 6 pack of Varta AAA's (cheap low capacity crap) so far, will get some rechargable energiser AAA's I think, I keep leaving the switch on when I go home from work)
However, I've never been able to deal with the white noise generated by Noise Cancelling Headphones, if its not perfect it makes a slight noise which makes me a bit queezy after a while. So even on a plane, I need to have some sort of music playing, then it doesn't effect me.
So every bacon sandwitch knocks off half an hour of your life.
Struggling to believe alot of what is written in the article
When you consider how third hand the information is, there is no reason you should believe it. Even research supported articles can be total bullshit, taking shady research findings out of context or misquoting or contradicting.
We live in an age where we've never had easier and greater access to information...an unfortunate byproduct of that is our exposure to equally large quantities of bullshit.
Neg.
When selling on behalf of bank agent has zero control the regs on bank sales are super tight
How did you know it was a bank auction?
Yeah the only nutrition advice I read atm is from Alan Aragon and Layne Norton
I don't even take nutrion advice from experts, rather just experiment with my own body and go from there...everyone is different so half the stuff they say doesn't work for everyone anyway.
  • Like 1
this.
my favourite part of the article: it used to be ok to drink 6 cups or coffee/tea a day.
its true though that recent studies have shown sugar to have a larger affect on general unhealthiness than fats. and ive always preached brown/black bread is the only way to go. f**k those white loaves. #breadracism
Guest
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 2 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
